space ranger
space ranger
http://replay.marpirc.net/inp/3/2/3/ppk ... olf147.zip
this game does not even rack-up a credit
too bad 'cause this one is tough.
i scored 8800
can someone check these ?
Re: space ranger
I'm not getting this one to playback either, at all..
http://replay.marpirc.net/r/spacerng
Re: space ranger
one more try will be three strikes
simpson or kernzy ?
kernzy
Re: space ranger
Post by kernzy »
you gotta be kidding me?????????
it took ages to get that score!!!!!!!!!!!!!!
#-o :(
kernzy
Re: space ranger
Post by kernzy »
does this one work?
have a butchers, let me see where the problem lies...
spacerng.zip
(156.2 KiB) Downloaded 250 times
kernzy
Re: space ranger
Post by kernzy »
and then please try this one....
cheers!
spacerng2.zip
(36.59 KiB) Downloaded 240 times
Re: space ranger
spacerng.zip playsback to 3640
spacerng2.zip playsback to 850
http://replay.marpirc.net/inp/3/2/3/ppk ... olf147.zip never starts
Tar's 8k playsback ok.
kernzy
Re: space ranger
Post by kernzy »
ok, so they both work, then.
so the one in question should also work.
i don't know what happened, and i've deleted the original file!!!
#-o
cheers Skito!!!
your help is welcomed. :D =D>
Re: space ranger
kernzy wrote:so the one in question should also work.
recordings only work if they work, this one doesn't, yet. you should test your recordings before uploading is the moral of the story. I thought it might be if you deleted the BAD DUMPS from the rom but mame doesn't let you play it back if it's gone, maybe if your bad dump roms are bad, but in that case all recordings probably wouldn't work and some do.
kernzy
Re: space ranger
Post by kernzy »
:-k
